2007-06-05 08:52 PM
2007-06-05 09:34 PM
2007-06-06 12:44 AM
2007-06-06 10:21 AM
2007-06-17 06:44 AM
mahmouha_86 wrote:The vrml generated by ArchicAD does not need to be compressed, it needs to be optimized (corrected, adjusted and improved), wich is different.
Hi all, hope you are fine,
i want to ask about something please..
now i'm using archicad to create vrml world for virtual mall... , first i created the building and put object inside it...
then i would like to save it as wrl file "vrml world" ... but when i tried to open it using VRML viewer.. it was so big and hard loading.. so i cant open it.. because it's size... so.. i tried to save each object as a wrl file and attach it in a wrl main world... but it will be a very complex task to save each object if i have over 100 object in the project....
i ask if there are a solution for saving the project as VRML world in a simple way.. and small size or to find a way to save the hole project as many wrl files file to each object without saving each object separately!!! or any other ways to be able to create my VRML world ??????
waiting for a replay as soon as possible
