‎2006-05-30 08:51 PM
‎2006-05-31 03:45 AM
‎2006-05-31 07:03 AM
‎2006-05-31 09:13 PM
‎2006-05-31 11:17 PM
vincon2 wrote:
I create an independent detail and paste that schedule in the new independent detail
Mike wrote:
... the view (in AC9) needs to stay in the plan window......
‎2006-05-31 11:34 PM
‎2006-05-31 11:41 PM
gbley wrote:I guess I'm missing something, thats not how I was taught. Karl if your out there, didn't you guys teach us to set up independent views for schedules at the Yosemite retreat?
My approach with the IS is to insert it in the plan window as Mike Hann says but make it 100-200 feet from your plan, zoom into it and set up a view with layer combination, display option, scale etc to the view editor. Open PM and import the newly saved view. No need to save it to a detail window. Am I missing something in this?
‎2006-05-31 11:51 PM
‎2006-06-01 12:37 AM
gbley wrote:I just realized I was using the worng nomenclature. I don't set up independent views, I create an independent detail and paste the schedule in that detail, then I save that detail as a plotmaker view set. If I don't do this , I'm not aware of a way Plotmaker can see the schedule.
Independent views yes. Independent windows aren't needed as far as I know. Setting up an independent view from the plan sheet won't change any other views from that same sheet you have created. Layers, display options, zoom, etc are view specific not sheet specific.
What I described is setting up an independent view. Also, the only way I believe that the schedule can be interactive with the various doors and windows is to be on the same plan sheet with those doors and windows. Anybody else on this?
‎2006-06-01 12:48 AM
