Window Configuration - Adding a Double Door
Hey Guys,
Using CADimage window maker, I want to add a double swing door in this window configuration (which is easy), however I need to make one door smaller then the other. Not using door maker as the window maker gives me options with the overall window configuration.
Not sure where I can do this in the settings. Using AC 21
anyone know how to do this?
Thanks in advance.
(P.S - emailed CADimage with no reply yet, so thought I'd ask the good people here)
1 REPLY 1
I don't see an attachment of what you are trying to create. Could you post again?
Gerald Hoffman
ā€œThe simplification of anything is always sensationalā€ GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
