Window Schedules - Header Height from Finish floor
I am looking to show the window header height from the T.O finish floor as well as from the "header to wall base" on the window schedules. I see you can add subfloor thickness to the window dimension marker. Any way to show these values in the window schedule as well?
3 Replies 3
If you can't get the information you need directly in the schedule, you will need to create a property in the window that can do the calculation you need and then you can schedule the result of that property.
Similar to this post that was submitted just the other day.
https://archicad-talk.graphisoft.com/viewtopic.php?f=34&t=68861
Any way to get subfloor information in your window schedules? I see you can add the subfloor dimension in your window tag, but I cannot seem to get window header to finish floor on my window schedules.
Minja,
There is no need to post multiple times for the same subject.
I have merged your 2 posts.
