Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Working on PLN file with both 64 & 32 bit systems?
While all the workstations at our office run xp 32 bit on AC13, one of the guys just bought a new Sony Vaio with windows 7. I installed AC13 on it in 64 bit. I just copied a pln onto it to test it out, and when opening the file I got a message to the effect, "This file has not been opened in a 64 bit system before. There may be problems if you try to save it and open it with a 32 bit system."
Could someone please let me know more about this? Specifically: is this really an issue and you are not to try to work on plns with different bit systems, or is this a message which is pretty much to be ignored? I don't know and can't judge the seriousness of the message. I guess I am finding it hard to believe that people with different bit systems wouldn't be able to work on files together. I would have thought there would be a lot more screaming in this forum, and when I searched for this issue, I couldn't find any remarks.
Thank you in advance for your time and help,
Foster
2 REPLIES 2
Erika Epstein
A 64 bit machine can handle significantly larger and more complex files than a 32 bit machine. The warning is because a 32 bit machine may not be able to handle it.
That said, most people here work on files, even 'large' ones that are not a problem on 32 bit machines.
I have had no problems opening such files on 32 bit, but then again I am not rebuilding Hong Kong
Go ahead and open it.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi Erika,
Thanks for the reply, I appreciate it. We do mainly small projects, so I am sure it won't be an issue.
Foster
