Zones disappear from IFC
Hi guyz!
I have an IFC file exported from Archicad. when I view this IFC file with other programmes such as Solibri or any IFC viewer programmes, everything is working fine and I can see the zones.
What I'm trying is to IMPORT this IFC file (since I don't have the original PLN/PLA) and by importing it to Archicad the zones just disappear! I check view in 3D option, I check the layer and everything look fine.. I even tried other translations when importing/opening the IFC file into Archicad, still have the same problem..
I tired Archicad 16,17 & 18.
Any help appreciated!
1 Reply 1
Zones usually don't show in 3D in Archicad by default.
You need to open the 3D filter settings and make sure 'zones' are on.
