alignment of 3d views in schedules
i'm doing door and window schedules for the first time using the built in interactive schedule tool; i own cadimage's door and window builder and have previously been using that.
as shown in the attached image, it seems the 3d front view (and i would assume other available views) are being aligned in the schedule grid by the vertical mid-point of the generated drawing (the red dashed line shown). I've added additional dimensions and floor levels using annotation function.
is there a way to adjust this alignment, e.g. align by top or bottom of frame or even better, floor level? even manual adjustment in the schedule so that it looks right would be preferable.
2 Replies 2
Kombibob,
Open the schedule and select one of the images.
On the left you will see an "Align preview to:" section.
thanks Barry; it was hiding in plain sight all along.
i guess wanting to set the alignment separately for each item (or at least elements on each story) is not possible; i'll try setting up a separate schedule for each story to see if it works.
rob.
