archicad 20 schedule curtain wall like window
Hello everyone,
Does anyone have made a schedule for curtain wall ( elevation and 2d plan).
7 Replies 7
I have a result but i need help
The first image is the setup for criteria
The second image of the curtain wall. We can get the 2d plan and the 3d to appear but the 2d from view we have a blank.
In the same schedule under the previous we have the ID with each panel showing.
Just to remind this is archicad 20, are we missing something.
Still no 2d élévation view and it like we have all the same ID. For the dimension it ok but it is in inch.
We are getting better. For the ID at the start we use curtain wall ID didn't work so we try compact element ID and it work.
But for the elevation we didn't find any solution
I am having the same issue. I have a large project with multiple slanted/angled curtain walls and would hate to have to draw them all.
What you get 'mhoude' is way better than what I can produce. Do you want to share your XML exported schedule file, so i can try it please. Mine reproduce totally incorrect on the schedule. I don't know why... see image.
Using Archicad 20 (5025)
