archicad project location / autocad WCS / reference
I need help with placing of my project.
What I need?
When I export my data from AC, then the location and rotation of my project/house/etc. I need to match those in autocad as WCS (my subcontractors data or land-registry-maps are in WCS).
In other words I start my AC project in zero. I want it to keep that way and reference it to the north/zero, same as revit works with Survey Point.
Thanks for the help
1 Reply 1
Hello se77e,
All 3d software has a spatial limit which is around 80km for Archicad. It is then necessary to draw close to the absolute origin of the working file.
To have a DWG with the project-specific reference system, all you have to do is compile your DWG from archicad in a worksheet in which you have previously discarded the reference DWG (far from the origin). Once your DWG is repositioned, just re-publish your DWG from the worksheet.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
