architerra help!!
I have a topography map in autocad, I´m bringing dxf drawing to archicad, (the drawing is coming with hotspots and the contours lines) I do all the steps as in the manual, but I can´t see my terrain in 3d. Someone can help me? I may be doing something wrong, but I don´t know what.
Thanks, for any replay.
4 REPLIES 4
Djordje
Do a serach of the Forum on ArchiTerra; the problem above was extensively discussed. Plus, I am sure Fabrizio will jump in soon
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
1. save your survey as DXF document from AutoCAD
2. import the DXF file using ArchiTerra
3. set the DXF drawing unit and define the layers from which you want to import the data
4. using the outline tool define the terrain perimeter
5. click on the Terrain icon in the ArchiTerra palette to build up your terrain.
Nothing else!
If this doesn't help, please, try to be more specific and detailed because "I can´t see my terrain in 3d" is not enough...
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Fabrizio, thanks for your help.
why sometimes the terrain doesn´t read as the outline line?
