autodesk is preparing for a huge step foward!
Dear graphisoft,
I still think archicad is far much better than Revit... but after seeing tools like Railclone for 3dsmax (astonishing parametric modeling tool) i think autodesk is willing to take revit to another dimension in terms of modeling with Dinamo, check this out!
https://www.youtube.com/playlist?list=PLAQfn-QKbiAkYnQoxuk7AdT8ZQjmNyGXr
Hoping to hear any thoughts!
cheers
11 REPLIES 11
NandoMogollon wrote:
Hi all, GedSta
Or is there a way to model everything parametric in rhino, then attach the geometry to archiCAD and then assign what kind of geometry it is (beams, trusses etc.) and model the standard things in archiCAD with the parametric objects in place and go forth and back between them?
check Geometry Gym an add in developed by a South African company. With it you can export from Rhino/Grasshopper and get into ArchiCAD as native elements ( beams, columns, walls, slabs, etc...)
Just a small point but he's actually Australian, I believe (the guy who made the plugin)
correct, my mistake, He is Australian.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
