cadimage wall builder (NZ)
I am trying to find out how to reslove the following question with walls- cadimage wall builderm part of the accessories tools.
When i add a wall builder (cladding) to a wall be it composite or fill pattern and I have an hidden wall underneath from my demolition walls layer, the wall builder breaks either side of the wall.
I have tried changing the different walls to different intersection group numbers and display order without success.
Thanks in advance
3 Replies 3
Probably your only option is to strighten up the mitres, and stretch the accessory across the gap joining it to the other side using the editing nodes in plan view.
Try trimming the demolition walls to the inside face of the exterior walls which have the cladding attached. If you can keep them from auto joining they will not be seen by the add-on.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
Erika Epstein
Thanks in advance
Have you turned on all the layers to see if there is another object that might be causing this gap?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
