bgoodale
conflict between Archistir and CADimage
i posted about this on the Cigraph website forum, and have emailed Cigraph repeatedly with no repsonse. At least one other person on the Cigraph forum has encountered this problem:
I am using AC12 EDU, and have installed Archistair and the Cadimage Suite of add-ons. Archistair worked fine before installing the Cadimage add-ons. But now the library parts for the posts and newel don't appear in the Archistair dialog, and the Panels dialog doesn't work at all.
I moved the Cadimage folders out of the add-on folder and Archistair works ok again, but now the Cadimage tools won't load properly. Does anyone know how I can use both of these add-ons with out needing all these wacky work arounds?
I am starting to wonder if this is some sort of corporate sabotage battle between the two add-on companies...at any rate, I am stuck in the middle because neither company seems willing to respond or address the issue.
Any help would be much appreciated. Thanks.
AC 25
WINDOWS 10
AMD Ryzen 9 5950X 16-Core Processor 3.4 GHZ
128 GB RAM
64 Bit Operating System x64 based processor
AMD Radeon RX 6900 XT
4 Replies 4
Hi, i haven't come across this before.
Are you trying to use Archistair & Cadimage's Stairbuilder?
As it might just be both their plugins trying to action separate thing at the same time.
bgoodale
well, i have them both installed, but i am not trying to use them on the same stair, or even in the same project. but having Cadimage ad--ons installed definitely messes up Archistair.
AC 25
WINDOWS 10
128 GB RAM
Brett Brown
Which Archistair are you using? I had the same problem with Archistair1. Problem went away with the new Archistair2. It was a while ago and Fabrizo did suggest to remove all other addons to test, but that didn't fix it for me. We never did find the problem.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
bgoodale
I am using Archistair 1. As far as I know, Archistair 2 hasn't yet been offered for Edu version. It would be great if they did.
AC 25
WINDOWS 10
128 GB RAM
