convet arc11 full v to arc10 ed v - wont work :( HELP!!!!!!
heya im looking to move my file from archicad 11 full version to archicad 10 educational version.
when i save it as a v10 file and take it over all my interior goes to small circles, and when i save it as a dwg file it just comes out a little pixelates ( some of the curves go to small lines)
please help.
i need to do this as the printers are only hooked up to the edu version and i am unable to hook them up to the full ver, i can print on cad if that is any help but still wen i save as a dwg file it does the same.
PLEASE HELP SOMEONE!
Thanks
If its only for printing purposes why not publish to PDF and print that on the other machine?
"s2art" wrote:
If its only for printing purposes why not publish to PDF and print that on the other machine?[/quote
just tried that and it still comes out with heavy lines
Sounds like you have some PDF/printer troubleshooting to do. Does the PDF appear correctly on the originating machine? (Remember that you have to zoom in at least 200% to see line weights).
