evermotion archmodels compatibility
Hallo. I'm working with archicad 10. Is it a good idea do buy evermotion archmodels. Can i use them - import them into archicad?
Thank you
3 Replies 3
yes! u can import 3ds
however with the rendering capabilities of archicad evermotion models are overkill
Well, yes, but it is not recommended...
The way better method is to make the whole building, and than in 3d max( or other 3d program) to import those models, and to render it with v-ray, brazil...
It depends on what you use for rendering. I use Max and I usually assemble them in Max.
