hairlines in autocad
Is there a way that when drawings are saved as in autocad format (2005)all lines in the translated drawing are hairlines? I click off true line weight on screen view options, I used all available translators, I searched the forum. But I cant fix this. Please help
14 REPLIES 14
Andy Thomson
ALT+6 is the command on a mac - this thing (see screenshot)
It will be somewhere else in your WE - but it is with this group of commands:
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
I did this but still it doesnt work. Strangely in my house it works. Ill try to log in as an administrator next tuesday to see if I can activate this button.
In the past some functions will not work if I log in as a user -for example Door & window builder. Ill keep you informed . Thanks for the help.
Everything works fine on a different file.
Ill try to make a new file and merge the problematic one to it.
Thanks to all. I'm glad it was not a bug
Andy Thomson
Just a general warning about DWB and DWG's - they don't always play nice. Try unloading the plugin and see how that affects things. I believe CI is working on this if they haven't fixed it already.
Director
Kristen
I have the exact same problem in AC12 now. It worked fine in AC11 but now the "Do not export ArchiCAD penweights" is grey and I cannot choose it. I have tried different combinations and I do not have true line weights on but it is always unclikable. Does anyone know how to activate it?
Kristen Broberg
AC 23 SWE Full on Windows 10 Pro
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
