2026-09-11 11:03 AM
I've received an AutoCAD 2D floor plan. I want to model it in 3D using ArchiCAD, but I'm having trouble creating walls due to the constant changes in wall thickness. Is there a way to address this issue?
2026-09-11 11:12 AM
As in the walls change thickness along their length? You could use the Trapezoid Geometry Method for your walls.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2026-09-11 12:02 PM
Ling, thanks.
I tried it, but the thickness keeps changing a couple of times along a single wall, and I struggled to adjust the parameters the whole time. I was wondering if there were any tricks with "Magic Wand" that I could've used. AI suggested using Fill and Morph Tools, but it didn't help
2026-09-11 01:27 PM
Can you show an example image for the problem you are having?
