importing DWGs - how to replace AutoCAD linetypes?
Here's the problem:
I need to import several DWG files several times into a ArchiCAD file.
I would like it to be so that certain AutoCAD linetypes would be replaced with suitable ArchiCAD linetypes (and those replaced AutoCAD linetypes wouldn't be imported, because in a few weeks I'd have thousands of useless linetypes).
So is there a way to make a translator that would replace AutoCAD linetype n with ArchiCAD linetype m (without having to write those linetype names down by hand with every DWG, since the imported linetype name seems to be related to DWG filename)?
0 Replies 0
