line breaks when exporting to cad
heya, when i export my files to cad they appear to have line breaks when i print them. anyone know why - its quite annoying.
another thing, does anyone know how to export a plan into photoshop without pixilating, ive tried a pdf but it still happens.
haha - basically i need to print in another programme because the printers i use are hooked up to an edu version of ac10. i am lucky enough to have the full version but when i convert it to the edu file all my objects go missing.
any help is appreciated
thanks
2 Replies 2
Thomas Holm
KRAY345 wrote:
any help is appreciated thanks
You've got your help in another thread. Please don't double your questions.
http://archicad-talk.graphisoft.com/viewtopic.php?t=19924
The bottomline is to remove the "blank background" or "white fill" of ex-archicad drawings.
I use the Model View tweaking (for DWG convertion) to use the setting for all View Maps (pict below), by making a new name ("Store as...").
There is also another simple way:
right-click the view map drawing>
Section Settings.../Elevation Settings... >
Model Display >
UNCUT ELEMENTS >
Fill Uncut Surfaces with: >
" N o t h i n g "
It works as same as the first one, but only for particular setting edited View Map(s).
AC11-1200
