Paul:
I took a look at this object and there are no rotation parameters. You have a few options:
1. If you know GDL, add a rotation parameter to the 3D Script of the object.
2. Without GDL, create a new object by viewing it in the 3D Window from the desired top and use the
Save 3D Model as command; in the Help files see Virtual Building > Parametric Objects > Graphic Creation of Custom Objects >
Saving 3D Models as Objects.
David
