new row in door schedule
yes, column
helpmeplease wrote:
1. How do I create a new row right after the mark row to identify the location/ room name for each door?
Do you mean "column"?
helpmeplease wrote:
2. Is it possible under "size" to make the W column read "PAIR 3'-0"" instead of 6'-0" ?
Only with GDL programming within the door objects.
Open Scheme settings (press the button above right corner of your schedule, open Fields/Door List panel, expand Window/Door subtree in available parameters list, select From Room, and press "Add >>" button. Drag the field upper in Selected Fields list. It should be placed just under Library Part Name field.
It is impossible, but you can use some trick for it. But you need to be more familiar with interactive schedules. List all door with Library Part Names, Widths, and User Definded 1 fields only in a schedule. You can locate User Definded 1 field browsing for any door object under "Additional parameters" button. Group identical items in this schedule and copy Width value into corresponding User Defined 1 field. Write "PAIR 3'-0"" instead of 6'-0". Now replace Width field with User Defined 1 in your original schedule and enjoy.
