objects in artlantis
does anybody knows how can I move the position of the centre of coordinates in an object at artlantis?
Thanks
1 REPLY 1
HI,
In the current version you can do that by opening the object in Artlantis as a scene. Then use your camera viewpoint and set it at the position you need the new origin point of the object. In the objects inspector choose camera target as origin point. Then use the command: menu/export as object.
The object will be saved with a new origin point. Be wise to give your object a new name.
In the next version you will be able to set the origin point of your objects in the preview window as you are placing them in your scene.
I hope this helps you.
Sjaak
