I have a project which originated in AC 12, i have converted it in AC 13 and i have used the oriented view new feature to rotate the floor plans.
Now when i publish to dwg with any of the translators two things happen:
If the "Save layout into Paper space with cropped view content" option is selected, then the resulting dwg, has serious parts missing. By missing i mean a whole area where walls, zones etc used to be, is completely blank.
If the "Save layout into Paper space with full view content" option is selected, then the dwg, has its full content as it should, BUT a lot of thing are not rotated correctly. For example zone names, door markers etc.
Anyone has encountered the same problem.
I know the answer will be "Use the full view content", but this creates huge files.
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
