reduce density of curve imported from rhino
Hi, I imported dwg file from rhino to Archicad with lots of curves to clean them up. With very dense control point from rhino, it seems really slow to work within ArchiCAD. Is there a way to reduce the density of the curves to increase the responding speed in ArchiCAD instead of tracing it again in archicad?
1 Reply 1
You can try converting the geometry into Morphs and then use the "Design>Modify Morph>Modify Segmentation" command to try to reduce the number of segments.
