saved dwg opens suuuuper small in autocad
I've saved a floor plan from Archicad 11 as a dwg. I saved it in the standard conversion settings. When insert the dwg into an exisiting Autocad plan, it comes in just as a speck. I can't even see it, but if I "select all", it selects something.
What could be going wrong? What else can I try?
Thanks
1 REPLY 1
Thomas Holm
Check the Drawing units (DWGUNIT) in your translator settings. It must match your setting in Autocad.
