sharing data with builders for estimating
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-05-01 03:41 PM
2007-05-01
03:41 PM
John Hutchison
Labels:
- Labels:
Data management
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-02 06:04 AM
2007-05-02
06:04 AM
You need to work backwards. Take your last budget spreadsheet, isolate the 'model elements' and think about how you will build the model to get that item-data in your schedules.
Does that make any sense? The more accurately and completely you actually model your building in ArchiCad, using complete, discrete lumber objects, drywall surfaces (as opposed to composites) - the more you actually 'pretend' that you are assembling a building, the more accurate your schedules will be, and the more real your schedule-derived budget will be. We don't model composite 'roofs' or 'slabs' anymore, we put monolithic 'slabs' of concrete on steel decking though (SEO with dnwds subtraction) - and we put plywood 'sheets' on trusses, etc. That way, we can treat all of these items as discrete, readily accessible quantities that can belong to a budget/masterformat outline specification or whatever - and tell us how much of the thing there is - and better yet, with objects, we can add or fill out the exact parameters we want to see in the schedule - such as cost, mass, volume - or even energy loads!
We calculate energy loads from all electrical appliances and lighting now right inside of ArchiCad. (see our blog post on the Electrigon Object and schedules)
Everything that has a given parameter, can be called in a given schedule.
That applies to switches, purlins, siding, millwork - anything.
Simple answer, model everything. Cant-strips, backfill (complex profiles) - and be smart about how you label these things (ID by CSI 2004 division is how we do it, since there is a 15 character limit to ID's)
Someday, we will post a blog entry about scheduling, we have about 10 projects in the loop that are going to end up in budgets this way...they are not ready to be 'published' yet though.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
Director
