simple problim when edit with c4d?
hi everyone
i know when make an edit with c4d the edit selection saved as object when send back to archicad ,in 3d view not a problem but in plan i se the object only in ground, for example when i make atwist to whole building i need see the effect of twist in whole plan not only in the set of object ,how i can do it.
thanks
1 REPLY 1
I've had similar problems in the past with archicad 10 and maxonform, the views in 3d are normally fine but in plan the newly created object is not clearly shown. I was hoping this was just an older software issue and that newer versions of archicad with the exchange to c4d would do this better...hopefully somebody with a better understanding of the software will be able to answer this as I'd quite like to know how it can be resolved.
Many thanks.
