I have never tried it on multiple objects.
Maybe the LP_XMLConverter can do this - I have never used it but I believe it can reset variables in multiple elements.
I may be mistaken though - as i say i have never used it.
Otherwise you will need to do it individually in each object.
I have done this in an object I made so I can easily reset all the array values back to default while I am testing or changing the object.
Create a boolean parameter called "reset_defaults_swch"
Then add this to the master script (it may work in the parameter script as well, but for some reason I have it in the master script"
if reset_defaults_swch = 1 then
dim my_array[]
my_array[1]="1"
my_array[2]="2"
parameters my_array = my_array
reset_defaults_swch = 0
parameters reset_defaults_swch = reset_defaults_swch
endif
Now just turn on the boolean parameter in the parameter list - it will turn back of instantly but will have reset your array.
You could do it without the boolean switch but you would have to manually uncomment/comment the lines otherwise it will always be initialising.
