SimpleTwig wrote:
The other issue is the default settings on many of the objects are also wasting lots of time.
This is a big problem with 'universal' libraries.
What suits on user may not suit another whose template has different pen colours, fills, etc.
As discussed you either need a visual legend of objects that have been set as you want them, or set u a lot of favourites, or edit the library (so effectively you have custom library parts) and never update it again until you really need to.
Personally I go the custom library route but then I am quite happy programming in GDL.
A new problem that stops the editing of library parts is the licensing of objects now in 16/17.
When set as 'public domain' then all is good because you can edit the objects - changing the default pen colours, fills etc., or even editing the scripts if you really want to.
However if the license is set to any of the other option then not only are the scripts hidden (which I have no problem with) but the parameters are hidden as well so you can't even change the default pen colour to suit your own template.
You have to resort to favourites or the visual legend or just edit them every time you place them.
I can understand objects needing protection if people are trying to make money from selling them but we should be able to tweak the parameters to suit our own particular setups.
Rant over!
