The 'Save Selection As Library Part' is just a menu (folder) that you can create yourself if it is not already in the existing menus.
In that menu you then add the commands for save as object, door, window, etc.
There is also a command for other special component subtypes - No CC Subtypes.
These subtypes are GDL objects (macros) that are part of the loaded library.
For things like door leaf, handle, curtain wall frame, etc.
