2003-10-30 10:37 PM - last edited on 2023-05-30 01:08 PM by Rubia Torres
2003-10-31 12:52 AM
Link wrote:Hi Link,
seem to be the case in 8 or 8.1 (build 1290).
2003-10-31 10:56 AM
2003-10-31 02:34 PM
2003-10-31 06:34 PM
It sounds dangerous to be able to edit an XREF, since it might be attached to more than one file.I agree! I believe an XREF should remain completely uneditable. Or they should at least be by default, unless the user specifically chooses to make them editable during import. ~Most~ users want to have them as references, in my experience.
Is this behavior in any way dependant on HOW the xrefs are linked?It doesn't appear to be. The effects I described originally will occur using overlay or attach.
How does Archicad8.1's XREF handling differ from Autocad? (and I only want release version info).ohhhh, just a few more bugs AFAICS
2003-10-31 06:45 PM
Thomas wrote:except 'overlay' still asks for you to find the nested x-refs if it can't find them itself . . .
Overlay - is a link to a truly external file. With this link, in my view you should not be able to edit the XREF unless you open it ffor editing first. And I also think this kind of link should not bring in the layers of the external file, and when detached, no trace of it should be left.
