Archicad C++ API
ACAPI_RegisterModelessWindow‘s PaletteAPIControlCallBack couldn't debug
Hi.
I register modeless dialog by ACAPI_RegisterModelessWindow api.
But the breakpoint can not enter callback function when debugging.
I want to know why can not enter callback.
Akos Somorjai
The dialog you register should inherit from DG::Palette:
class FavoritePalette : public DG::Palette {};
Could you please show your ACAPI_RegisterModelessWindow() call?
Also, make sure that you return APIAddOn_Preload from your CheckEnvironment() function.
A trick: add a GUID for your palette, and generate the reference ID from it, to ensure that it's unique:
const GS::Guid paletteGuid ("{DAA252EE-CFB4-42BA-8483-0D255D03D17E}");
const Int32 paletteRefId = (Int32) GS::GenerateHashValue (paletteGuid);
then use these in your ACAPI_RegisterModelessWindow() call.
Best, Akos
Akos Somorjai
Best, Akos
Best, Akos
Thanks.
According to your method, this problem is solved.
