Developer forum
GDL coding questions, Python and add-on development using the API Dev Kit.
APIERR_REFUSEDCMD when delete story
		API_StoryInfo storyInfo;
		BNZeroMemory(&storyInfo, sizeof(API_StoryInfo));
		GSErrCode err = ACAPI_Environment(APIEnv_GetStorySettingsID, &storyInfo, nullptr);
		API_StoryType** storyType= storyInfo.data;
		API_StoryType* temAdress = (*storyType);
		//删除楼层
		for (int i=storyInfo.firstStory;i<= storyInfo.lastStory; i++)
			API_StoryCmdType changeType;
			BNZeroMemory(&changeType, sizeof(API_StoryCmdType));
			changeType.action = APIStory_Delete;
			changeType.index = temAdress->index;
			changeType.dispOnSections = true;
			changeType.dontRebuild = true;
			changeType.elevation = temAdress->level;
			//changeType.uName = temAdress->uName;
			err= ACAPI_Environment(APIEnv_ChangeStorySettingsID, &changeType, nullptr);
			temAdress++;
I try to delete story by the code above ,but it didn‘t work , and the error code was "APIERR_REFUSEDCMD -2130312312 81060388 The passed identifier is not subject to the operation. ".I can not find why.
1 REPLY 1
Viktor Kovacs
Probably it doesn't work because you try to run a command that modifies the database, and the command is not in a command scope. Try to do it like this:
ACAPI_CallUndoableCommand ("Delete Story", [&] () -> GSErrCode {
    // call APIEnv_ChangeStorySettingsID here
It's your choice if you create a separate undo step for all stories, or to do the whole modification in one undo step.
More information here (under the undo scope section):
https://archicadapi.graphisoft.com/archicad-maze-generator-add-on-tutorial-part-1
