100,000 to 1000000
Is it possible to change the way Archicad shows dimensions, in terms of not showing any commas ??
The local building department likes to see centimeters 1000 and not 1,000.
Even after I change the Regional and Language Options settings in WinXP Home to what I want, still no change in Archicad.
TIA
Naftali
ArchiCAD v8.1 R2C Build 2284, winXP Home
Oleg
It is possible just in the Regional Options, but you need close and launch ArchiCAD again after you done some changes there. And then go to ArchiCAD dimension preferences, change it to the meter and again to centimenets and press OK. It will change placed dimensions to the new format. Did you it.
I am on Win2k but I think it will work on XP same way.
Thanks Oleg,
That did the trick !!
Naftali
MarinRacic
It works on OS X, too! I've tried it just a few seconds ago...
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
