‎2013-07-22
02:27 AM
‎2025-02-07
01:57 PM
Aruzhan Ilaikova
‎2013-07-22 07:48 PM
Jonathan wrote:Mark's earlier instructions are how you make a copy. There is no 'duplicate' command is there is with materials, for example. Instead, just select the penset that you want 'duplicated' and start editing. Then, Save the pen set with a new name. (Saving with the original name is how you modify the original pen table.)
the idea is to somehow make a copy of this penset
‎2013-07-22 08:41 PM
Karl wrote:Jonathan wrote:Mark's earlier instructions are how you make a copy. There is no 'duplicate' command is there is with materials, for example. Instead, just select the penset that you want 'duplicated' and start editing. Then, Save the pen set with a new name. (Saving with the original name is how you modify the original pen table.)
‎2013-07-22 09:09 PM
