3D Document documentation
Cardiac
Hello members hope you are doing well.
I wanted to ask if it is possible for a 3d Document to show the image texture. Thanks
You can add a separate textured fill, but it will not be in perspective.
Although you could try distorting it with the fill handles.
No, no texture images.
Surface colours and hatch patterns only.
