2022-08-25 09:26 PM
This is not technically an Archicad question; but since most of you are part of the architecture profession, I would like your thoughts.
For those of you who work regularly in commercial architecture, how many of your firms have a standard, generic sheet of ADA diagrams and drawings with required dimensions that you include in your set? So a firm I work with does do this and does not bother to dimension things like toilet locations sink locations accessories locations, because it is "covered" in the generic sheet of ADA.
I feel uncomfortable about this as ADA is a design guide for us to work with in our designs and not simply publish for the contractor to figure out. But I would like to know form anyone else who is willing to weigh-in on this. I am more familiar with residential and have been out of Commercial architecture for a long time. Have things changed over the years and now firms publish generic ADA stuff on a regular basis now?
If so, this will effect our Archicad template to include the ADA sheet for every project. Thank you for your thoughts. So I guess it could be technically an Archicad question. I don't like the idea of including a sheet like this in a template. It is a small debate in the office.
2022-08-26 09:09 AM
You could have such content in a separate project file and just fetch that content via the external file into your project layout book if needed. They don't have to be a part of yout template.
The "ready to use" diagrams, room layouts, etc. I think have not much in common with creating architecture, but they can speed up the work process if you work on generic buildings.
| Archicad 4.55 - 27
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
