Add new working Units (eg Japanese Foot, Korean Foot)
Hello,
(1) Is there any way to add more types of working units, say Japanese Foot, Korean Foot....
(2) Any way to mark to dimensions (both in mm and special foot) with automatic translation (not just type in)?
Thanks
1 Solution
The only thing available is the Secondary Dimension feature. Its commands are found in the "Document > Annotation > Secondary Dimensions" menu. Select one or more Dimension Chains and use the "Convert Dimensions" command. Additional dimensions will be placed below the Dimension Line. However, it is not possible to define new Dimension units, you can use only those that are available.
Go to post
