Archicad Start 2020 - Graphic Overrides
Planit
Does anyone know how to create new Graphic Override Rules in AC Start 2020?
The location for this in other versions is Document - Graphic Overrides - Graphic Override Rules but AC SE 2020 doesn't appear to have this last command.
13 REPLIES 13
You are showing "All menus in alphabetical order"
Try using "All commands in alphabetical order".
You also need to choose a menu on the right hand side that you want to place the command in - otherwise the commands remain grey and un-placeable.
Planit
I dont think the Edit Rules command is there.
It seems that it is not there.
As Karl said, it looks like it is a limitation of the Start Edition.
Looking at the feature list in the specifications for Start Edition, there are no Graphic Overrides as Karl mentioned.
https://simbim.es/en/graphisoft/44-archicad-se.html
