Autotext line breaks
As queried in this wish is there a way of adding a hard return to a line of autotext, specifically on a Mac (I remember doing it in Windows). A good example if for a Layout title.
We have tried typing the required text in a normal text field and copy/paste into layout name, but this does not work.
A search revealed that wish linked above, hence the double post.
Cheers
17 Replies 17
Erich
S2art,
What are you trying to do? I have hard returns in the autotext from my project information. The returns are placed in the Project info text box and not on the layout. Does this fix it for you or are you trying to put returns into autotext from the system or somewhere else that might not allow that control?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
We are trying to control the point at which Layout names "break" or drop down a line
so we get
LAYOUT PLANS
GROUND AND FIRST FLOOR
and not
LAYOUT PLANS GROUND AND FIRST
FLOOR
We have #LayoutName autotext elements in the Master.
so we get
LAYOUT PLANS
and not
FLOOR
I can't remember if it is "/n" or "\n" (without the quotes) that forces a line break in text.
Does it help if you use this in the layout name?
Erich
S2art,
Hmmm, now I see what you are trying to do. Unfortunately I don't have an answer for this one. I smells of the general text formating limitations we face in a number of areas with AC.
Perhaps someone more versed has a work around? .......
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
owen
no idea how to line break the autotext .. i'm pretty sure i have heard someone on ACTalk say it can be done though (which is of no help - but we can't all be imagining it)
As a workaround could you use a simple GDL text block placed on the master with two PARAGRAPHS containing the Autotext? .. one for Subset Name (Layout Plans?) and one for Layout Name (Ground and First Floor?)
it may not give you the file names you want when Publishing to PDF though (or it may .. ive just been to a Bjork concert so im not really in an AC mindspace right now)
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Doesn't work for me, thanks.
I suppose you could just use two lines of text with separate autotext fields in them. Not a bad idea. I would probably try it the other way though, putting all my plan layouts in a Subset called "Ground and First Floors" with the Layout Names then being "Construction Plans", Electrical Plans", "Framing Plans", "Bracing Plans" etc. (mostly 2 storey residential type work, having type of plan as subset name would require LOTS of subsets).
We'll give it a go.
owen wrote:
(ive just been to a Bjork concert so im not really in an AC mindspace right now)
I can understand that.
I think this works only when the text you enter is used by some GDL object.
The reason is that \n is a character string that has any meaning only in GDL.
For example, if you use the \n characters once in the name of a Zone Stamp, it will break it into two lines (of course it will mess it up because now that line of the Zone Stamp which is supposed to be one line is now two lines, and other parts of the Zone Stamp's 2D Script "think" it is one line so it will overflow other texts in the Zone Stamp.)
This of course could be solved - in case anyone is interested - because you could check in the GDL code any line of the Zone Stamp to see if it has \n character string in it and then use the ADD2 command before drawing the next line of text below it accordingly to shift it by the correct distance. (Sorry if this does not make much sense to many, I am adding it for GDL guys.)
AutoTexts are not GDL so they cannot use this trick.
Link
So what trick can we use then?
I haven't fouind one yet.
Link.
Unfortunately I do not know of any either.
