Hi Karl,
I've modified the 3D symbol such that if wall material A = B there's no line and if they'd different, you'll have a hairline (as you probably wouldn't want to use a heavy line like the wall perimeter.
So, you can now use this for 'wall end' and 'returned wall'.
But, as GDL goes, this symbol should be even more of a 'jack of all trades' but without being too overly complicated, for example:
1. Brick composite with GWB interior: You'd like the demising line to be a double line to represent a reveal.
2. GWB clad partition with Paint A on one side and Paint B t'other I'd also go with a reveal to neatly stop the paint lines --- but it may not lay on the same line as the skins (ie. you may wish to have it 50mm in to give it some bite).
3. Wall surface A may be a feature surface intended to shoot past the wall end by 25 or 50mm for effect ---- likewise, it'd be great to have that built in.
I'd like to tweak this puppy and post it back for others to use - any help you can provide would be greatly appreciated.
I find the GS symbols to be hugely lacking in what should be their strength - parametric intelligence! Why have one symbol for 'wrapped end' (which doesn't work) and another for 'returned end' (which does work) when the symbol should be able to figure out it's condition parametrically!!!!
The only human intervention should be 'where do I want the paint line reveal' and 'should I extend this feature skin beyond the wall end'.
I want to design with wall surface A = B and then afterwards go in and make A <> B (even if its just colours) - and we should all reasonably expect the symbol to take care of that basic change for me!
But, given that GS can't do everything it'd be good for the AC community to help work on the refinements so:- Is there somewhere I can post the symbol for you and others to look at it?
Cheers Cameron
Cameron Hestler, Architect
Archicad 28 / Mac Studio M4 Max - 64 GB / LG27 Monitors / 26.6 Tahoe
- been using Archicad since V4.55
