4 weeks ago
I am on MacBook , so in order to SAVE file in PDF, I have to go through File > PRINT.... it is not through the standard routine, so I don't have choice on DPT setting either... in this setting I can only choose to chase in quality Draft, normal or high.
I just downloaded my project schedules in PDF, I kid you not, it is 140MB in normal quality, but draft being similar. I use PDF PRO, which have feature to make files smaller but it ends up being still 90MB. If I save it that way, the layout open VERY slow, IF. When I go to office to print it, the printer crash and I am unable print it.
I tried to simplified certain objects, even removing textures (ouch, because that's part of specifications), but nothing really helps. I know there used to be an option to find heavy objects in archicad but I can't no longer find it.
Anyone who can help please?
Solved! Go to Solution.
4 weeks ago - last edited 4 weeks ago
Really?! There's no File > Save as > PDF?!
This would be the way to go.
AC doesn't communicate well with 'printers'.
Fills with transparency are approximated with small 8x8 bitmaps - the real bitmaps; each pixel is '0' or '1' for transparent or opaque.
And you need a whole lot of these bitmaps for larger areas, wich leads to larger files.
Some screenshots, fill with 50%, bg pen 0; SavedAs and printed with Adobe:
SaveAs produces an object with trancparency, you could alter the opacity (and color).
Print produces a 100% opaque picture ('Bild') consisting of a pixel grid, every 2nd is transparent > 50%.
And yes, this is early '90s technology. 👻
4 weeks ago
First thing to check is fills! Check for fills you haven't used regularly!
I saw one years ago, that I think was a rock or stone fill, that would cause really large PDFs and would cause it to not print.
4 weeks ago
Image fills and dense Vectorial Fills murder AC's PDF output no matter if you SAVE, PRINT or PUBLISH.... Though you say that a SCHEDULE was 140mb...? What is on it?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
4 weeks ago
Given, the inbuild PDF Publisher will generally resolve the % fill cleanly to not be dotty... Still far from ideal...
4 weeks ago
Sometimes, when PDF are too slow/impossible to print, I use chrome as a PDF viewer and print with it.
I did check that too. Except a countertops and backsplashes, that need marble drawing fill or tile ( the bare minimum standard to show intent) and the rest I made white gloss paint including cabinets inserts. I assume white is the simplest way (?). But then I spent extra more time with schedules because I have to now put schedule annotation on every-single-cabinet since I can’t use textures. Awful.
My whole file is 140MB. Not a schedule…?
It’s larger residential project, about 10k SF, so a lot of cabinetry, elevation for each room, … i do need to use some surface fills to show intent. Architectural software would be almost useless if I can’t show some type of fills.
but even a floor plan takes forever to load in pdf. The plan from architect loads in second and has more annotations and more of everything (my floor plan is really cleaned out) . She obviously uses Revit or CAD… but her files are very light. And she has more in them.
I also found the addon that shows heavy files - it’s part of goodies and called something polygon. It helped with some items but didn’t really change the file size
4 weeks ago
I already have mentioned, the MacBook publisher isn’t ideal and on MacBook it change coloring of photos…. Completely. They told me to save pdf through print…. Yep.
4 weeks ago
- last edited
3 weeks ago
by
We built a free web app that runs entirely in your browser - pdf doesn't leave your PC and it it for this kind of troubleshooting.
pdf.vktrs.co
