yesterday
I am on MacBook , so in order to SAVE file in PDF, I have to go through File > PRINT.... it is not through the standard routine, so I don't have choice on DPT setting either... in this setting I can only choose to chase in quality Draft, normal or high.
I just downloaded my project schedules in PDF, I kid you not, it is 140MB in normal quality, but draft being similar. I use PDF PRO, which have feature to make files smaller but it ends up being still 90MB. If I save it that way, the layout open VERY slow, IF. When I go to office to print it, the printer crash and I am unable print it.
I tried to simplified certain objects, even removing textures (ouch, because that's part of specifications), but nothing really helps. I know there used to be an option to find heavy objects in archicad but I can't no longer find it.
Anyone who can help please?
10 hours ago
First thing to check is fills! Check for fills you haven't used regularly!
I saw one years ago, that I think was a rock or stone fill, that would cause really large PDFs and would cause it to not print.
8 hours ago
Image fills and dense Vectorial Fills murder AC's PDF output no matter if you SAVE, PRINT or PUBLISH.... Though you say that a SCHEDULE was 140mb...? What is on it?
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
3 hours ago - last edited 3 hours ago
Really?! There's no File > Save as > PDF?!
This would be the way to go.
AC doesn't communicate well with 'printers'.
Fills with transparency are approximated with small 8x8 bitmaps - the real bitmaps; each pixel is '0' or '1' for transparent or opaque.
And you need a whole lot of these bitmaps for larger areas, wich leads to larger files.
Some screenshots, fill with 50%, bg pen 0; SavedAs and printed with Adobe:
SaveAs produces an object with trancparency, you could alter the opacity (and color).
Print produces a 100% opaque picture ('Bild') consisting of a pixel grid, every 2nd is transparent > 50%.
And yes, this is early '90s technology. 👻
3 hours ago
Given, the inbuild PDF Publisher will generally resolve the % fill cleanly to not be dotty... Still far from ideal...
