Wednesday
I am on MacBook , so in order to SAVE file in PDF, I have to go through File > PRINT.... it is not through the standard routine, so I don't have choice on DPT setting either... in this setting I can only choose to chase in quality Draft, normal or high.
I just downloaded my project schedules in PDF, I kid you not, it is 140MB in normal quality, but draft being similar. I use PDF PRO, which have feature to make files smaller but it ends up being still 90MB. If I save it that way, the layout open VERY slow, IF. When I go to office to print it, the printer crash and I am unable print it.
I tried to simplified certain objects, even removing textures (ouch, because that's part of specifications), but nothing really helps. I know there used to be an option to find heavy objects in archicad but I can't no longer find it.
Anyone who can help please?
Solved! Go to Solution.
yesterday - last edited yesterday
Really?! There's no File > Save as > PDF?!
This would be the way to go.
AC doesn't communicate well with 'printers'.
Fills with transparency are approximated with small 8x8 bitmaps - the real bitmaps; each pixel is '0' or '1' for transparent or opaque.
And you need a whole lot of these bitmaps for larger areas, wich leads to larger files.
Some screenshots, fill with 50%, bg pen 0; SavedAs and printed with Adobe:
SaveAs produces an object with trancparency, you could alter the opacity (and color).
Print produces a 100% opaque picture ('Bild') consisting of a pixel grid, every 2nd is transparent > 50%.
And yes, this is early '90s technology. 👻
yesterday
First thing to check is fills! Check for fills you haven't used regularly!
I saw one years ago, that I think was a rock or stone fill, that would cause really large PDFs and would cause it to not print.
yesterday
Image fills and dense Vectorial Fills murder AC's PDF output no matter if you SAVE, PRINT or PUBLISH.... Though you say that a SCHEDULE was 140mb...? What is on it?
yesterday
Given, the inbuild PDF Publisher will generally resolve the % fill cleanly to not be dotty... Still far from ideal...
yesterday
Sometimes, when PDF are too slow/impossible to print, I use chrome as a PDF viewer and print with it.
I did check that too. Except a countertops and backsplashes, that need marble drawing fill or tile ( the bare minimum standard to show intent) and the rest I made white gloss paint including cabinets inserts. I assume white is the simplest way (?). But then I spent extra more time with schedules because I have to now put schedule annotation on every-single-cabinet since I can’t use textures. Awful.
My whole file is 140MB. Not a schedule…?
It’s larger residential project, about 10k SF, so a lot of cabinetry, elevation for each room, … i do need to use some surface fills to show intent. Architectural software would be almost useless if I can’t show some type of fills.
but even a floor plan takes forever to load in pdf. The plan from architect loads in second and has more annotations and more of everything (my floor plan is really cleaned out) . She obviously uses Revit or CAD… but her files are very light. And she has more in them.
I also found the addon that shows heavy files - it’s part of goodies and called something polygon. It helped with some items but didn’t really change the file size
yesterday
I already have mentioned, the MacBook publisher isn’t ideal and on MacBook it change coloring of photos…. Completely. They told me to save pdf through print…. Yep.
yesterday
We built a free web app that runs entirely in your browser - pdf doesn't leave your PC and it it for this kind of troubleshooting.
pdf.vktrs.co
