2021-10-21 02:06 AM
Although I had downloaded AC 25 when it was released, I only started using it this week, as I us Central Innovation Cad IMage tools in my projects, and I was waiting for them to publish their update for AC25.
In AC25, I'm unable to insert a new dimension point to an existing dimension string. I usually command click to add points, but it's not working. Nor does it work when I use the pet palette "insert new point" command.
Is this just a glitch in AC 25 and I should submit a bug report? Or is there something in my toolbox settings that is preventing this from working correctly in 25? I don't have the same issue when working in AC 24.
2021-10-21 02:20 AM
it appears that the issue happens when the dimension is set to "manually dimension each skin"
2021-10-21 04:19 AM
I don't know what is causing this for you but I can report that I can't replicate the situation myself. I don't use 'manually dimension each skin" normally but even if I do, control click adds a new node into the dimensions string as usual.
