2004-03-31
03:43 AM
2023-05-31
10:18 AM
Rubia Torres
2004-03-31 08:15 PM
2004-03-31 10:06 PM
Matthew wrote:OK, are you saying that in one view I might want some composites controlled by the Display Option settings while others aren’t while in another view it would be different ones that conformed while still others are free?
The issue is how to permit both settings by view and settings by composite without tying people's brains in knots.
2004-03-31 11:15 PM
2004-04-01 12:21 AM
Matthew wrote:Great idea, glad you thought of it. But how is this different than including control of composite appearance in the current Display Option settings, which is really just a matter of expanding the “Construction Fills” options by splitting them into two pull downs, one with fill options and the other with line options including the new “Core Only” selection. Isn’t this all we really need? It’s already been the subject of two recent polls,
A dialog to create named sets of display options for the composites (similar to the Layer Combinations). This way a Composite Display Setting could be easily selected for each view..
2004-04-01 12:45 AM
Geoff wrote:It is different by allowing settings for each composite. For example: at 1/4" scale a frame wall with brick veneer should display the brick but the rest of the detail; at 1/2" scale the air space might appear while the sheathing and GWB remain hidden; at 1 1/2" scale the full detail of the composite is shown: a simple concrete wall would show the same at all scales: an interior framed wall would only have two settings; with and without the GWB shown.
2004-04-01 05:11 AM
2004-04-01 05:14 AM
~/archiben wrote:Very good--thank you.
dave
not quite what you're asking, but a useful function that i find using composite walls:
http://archicad-talk.graphisoft.com/viewtopic.php?t=567
~/archiben
2004-04-01 05:23 AM
You're right Geoff. Display options also need to be considered.
The whole matter is rather complex though since the settings will vary with different composites. The problem with making the settings in the composites is that they become global in all views. The (potential) problem with using the display options is that they affect all the composites.
_________________
Matthew Lohden
2004-04-02 02:55 AM
Dave wrote:If they're new walls, they SHOULD all have their own composites - you need to know what walls you're putting in. However, if they're just part of the existing, what we do is use a 75% fill wall type (not a composite) and just adjust the thickness to what it measures out to in field. That way I don't end up creating all those composites, and keeps me from having the wall show too much detail in plan/section, and makes it easy to see what's new and existing to remain. Same idea with demo walls (different settings though).
I also dislike having to create a new composite for every wall thickness that occurs in a house. I have about 10 in a current project--and many won't be used in subsequent designs.
2004-04-02 07:59 AM
Sergio wrote:No, in my 1/4" plans I don't show gyp board and framing. I show a new wall with a 50% fill for all three skins and no separator lines. The special wall sizes I'm referring to have voids, i.e., gyp. bd./studs/air space/studs/gyp. bd. They vary in dim. from f.o. GB to f.o. GB. There's no reason to have a series of composite walls to handle these conditions except that AC requires it. I don't have AC open and I'm about to turn into a pumpkin or I'd take a screen shot.Dave wrote:If they're new walls, they SHOULD all have their own composites - you need to know what walls you're putting in.
