ā2018-12-10
06:48 PM
ā2023-05-17
09:17 AM
Gordana Radonic
Solved! Go to Solution.
ā2018-12-11 06:05 AM
ā2018-12-10 07:36 PM
ā2018-12-10 08:44 PM
ā2018-12-11 09:09 AM
ā2018-12-11 09:32 AM
Tomas wrote:No.
I have one more question. When using this workflow with full version of ArchiCAD, can you batch publish to PDF from multiple files at once?
ā2018-12-11 12:27 PM
ā2018-12-11 12:44 PM
Tomas wrote:There are several ways of building up more complex documentation. Usually, If our documentation exceeds 50 drawings we do separate file just for Layouts and link bunch of pln/pmk to Documentation File. Then you control the whole doc from one place. It still takes bit more time to update Drawings but it's done mostly automatically (AC opens other files in the background).
ā2018-12-11 05:54 PM
ā2018-12-12 11:13 AM
Tomas wrote:Why? We do it for big and small projects whenever we got multiple instances of the same element. It's a very efficient way to in terms of management and performance of the project.
separating furniture into independent files is not an option
