Construction material representation section cut
I created a construction material with a specific represetantion for a wall, wowhever when i make a section the representation of the wall seams to be out of place, in the floor plane the representation is correct. Someone knows how to straighten it up?
Podolsky
Ace
You need to use composite structure for wall - even if it's only one layer of material.
In Building Material settings choose "Fit to Skin" Fill Orientation.
