Controlling dawing order when generating a plt file
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-04-10
08:37 PM
2025-02-07
03:44 PM
Aruzhan Ilaikova
2006-04-10
08:37 PM
Hi All -
My print shop has been complaining about the order of drawings contained in the plt files we give them. In plotmaker it is possible to specify the print order when selecting multiple drawings to print - however, this function is grayed out when plotting. Does anyone know of a solution for controlling plot order?
Thanks,
Don
Thanks,
Don
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-10 10:05 PM
2006-04-10
10:05 PM
Plotting saves multiple files (one for each sheet) which are then ordered by the file system. I theory it could be possible to order the files by their date/time, but in my experience this is not reliable. AFAIK the only way to control it is by naming the files accordingly. You can set up a publisher set that names the files with leading page numbers to keep them in order. (You could also do this in the layout names in Navigator but this would presumably screw up your sheet numbers in the title blocks.)
There may also be a way to set the order using Océ's Reprodesk software before sending the files but I am not sure about this. The file order can certainly be rearranged in Reprodesk at the service bureau but they probably don't want this chore and neither do you want to depend on their accuracy.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-11 06:27 AM
2006-04-11
06:27 AM
Yes, if your printer uses an Oce, they will install on your office computer, free of charge, the Reprodesk/Buzzsaw program.
It allows you to easily rearrange the drawings as well as preview what you will be getting!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-04-13 03:29 AM
2006-04-13
03:29 AM
Don't give them .plt's. Give them PDF's instead. No worry about pen weights, etc. Create one pdf file in acrobat File>Create PDF>Multiple files. PLT files are soooo 20th century.
