Creating two door leaves with one frame (inside and outside, kinda like hotel connecting door)
Hi, I have a project that needed to draw a door with additional insect screen door.
Is there any way to create that using door tool?
What i have done is create 2 doors, 1 normal door with frame
and the other is door leaf only (by putting frame width and depth value to 0)
this is what it looks like
but the problem if i try to put 0 value to the frame width, the door will have a blue line on 2d symbol which is printable
and i couldn't find which option to turn it off
blue line on the leaf only door that i wish to remove
Would be appreciated for the help
Thank you
1 REPLY 1
I don't use these door objects but having a quick look I think this will work.
Set a 'double rebate' to the frame and adjust the sizes so it is symmetrical to the frame thickness.
Then place 2 complete doors with frames.
